Time Before: 0.00131 seconds
Time After: 0.00176 seconds
Time Before: 0.00183 seconds
Time After: 0.00240 seconds
Time Taken: 0.00057 seconds
Time Before: 0.00260 seconds
Time After: 0.00275 seconds
Time Before: 0.00341 seconds
Time After: 0.00563 seconds
Time Taken: 0.00222 seconds
Time Before: 0.00280 seconds
Time After: 0.00911 seconds
Time Taken: 0.00630 seconds
Time Before: 0.01105 seconds
Time After: 0.01145 seconds
Time Before: 0.01398 seconds
Time After: 0.01552 seconds
Time Taken: 0.00154 seconds
Time Before: 0.01030 seconds
Time After: 0.01573 seconds
Time Taken: 0.00544 seconds
Time Before: 0.02111 seconds
Time After: 0.02126 seconds
Time Before: 0.02338 seconds
Time After: 0.02462 seconds
Time Before: 0.02766 seconds
Time After: 0.02783 seconds
Time Before: 0.02986 seconds
Time After: 0.03127 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=77788', badlocation = 1 WHERE sessionhash = '4107984102e2914075bf6bfb65da9afe'
Time Before: 0.04817 seconds
Time After: 0.04841 seconds
Memory Before: 4,911.938 KB
Memory After: 4,912.164 KB
