Time Before: 0.02363 seconds
Time After: 0.03126 seconds
Time Taken: 0.00762 seconds
Time Before: 0.03136 seconds
Time After: 0.03183 seconds
Time Before: 0.03208 seconds
Time After: 0.03222 seconds
Time Before: 0.03306 seconds
Time After: 0.03555 seconds
Time Taken: 0.00249 seconds
Time Before: 0.03228 seconds
Time After: 0.03990 seconds
Time Before: 0.04671 seconds
Time After: 0.04712 seconds
Time Before: 0.04981 seconds
Time After: 0.05112 seconds
Time Taken: 0.00131 seconds
Time Before: 0.04605 seconds
Time After: 0.05135 seconds
Time Taken: 0.00530 seconds
Time Before: 0.08715 seconds
Time After: 0.08732 seconds
Time Before: 0.25216 seconds
Time After: 0.25342 seconds
End call of global.php: 0.25662994384766
Time Before: 0.26697 seconds
Time After: 0.26714 seconds
Time Before: 0.27049 seconds
Time After: 0.27196 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=77942', badlocation = 1
WHERE sessionhash = '1b43d45bbaaa70ba8be59b846adc9cfa'
Time Before: 0.28874 seconds
Time After: 0.28905 seconds
Memory Before: 4,288.016 KB
Memory After: 4,288.242 KB
Page generated in 0.2875509262085 seconds with 9 queries, spending 0.0082032680511475 doing MySQL queries and 0.27934765815735 doing PHP things.
