Time Before: 0.02941 seconds
Time After: 0.03625 seconds
Time Taken: 0.00683 seconds
Memory Before: 1,157.773 KB
Memory After: 1,182.891 KB
Time Before: 0.03637 seconds
Time After: 0.03680 seconds
Memory Before: 1,182.828 KB
Memory After: 1,183.836 KB
Time Before: 0.03705 seconds
Time After: 0.03721 seconds
Memory Before: 1,184.422 KB
Memory After: 1,184.945 KB
Time Before: 0.03824 seconds
Time After: 0.04019 seconds
Time Taken: 0.00195 seconds
Memory Before: 1,187.547 KB
Memory After: 1,188.469 KB
Time Before: 0.03729 seconds
Time After: 0.04448 seconds
Time Taken: 0.00718 seconds
Memory Before: 1,184.164 KB
Memory After: 2,265.219 KB
Memory Used: 1,081.055 KB
Time Before: 0.05393 seconds
Time After: 0.05428 seconds
Memory Before: 2,758.023 KB
Memory After: 2,758.641 KB
Time Before: 0.05636 seconds
Time After: 0.05765 seconds
Memory Before: 2,770.195 KB
Memory After: 2,770.055 KB
Time Before: 0.05306 seconds
Time After: 0.05797 seconds
Time Taken: 0.00490 seconds
Memory Before: 2,750.172 KB
Memory After: 2,883.414 KB
Memory Used: 133.242 KB
Time Before: 0.08465 seconds
Time After: 0.08503 seconds
Memory Before: 3,436.539 KB
Memory After: 3,437.055 KB
Time Before: 0.10104 seconds
Time After: 0.10233 seconds
Memory Before: 3,524.336 KB
Memory After: 3,524.930 KB
End call of global.php: 0.10445594787598
Time Before: 0.11373 seconds
Time After: 0.11505 seconds
Time Taken: 0.00132 seconds
Memory Before: 4,162.242 KB
Memory After: 4,162.672 KB
Time Before: 0.11732 seconds
Time After: 0.12003 seconds
Time Taken: 0.00271 seconds
Memory Before: 4,443.805 KB
Memory After: 4,445.492 KB
SET lastactivity = 1788948560, location = '/forums/private.php?do=newpm&explain=1&u=78013', badlocation = 1
Time Before: 0.14219 seconds
Time After: 0.14249 seconds
Memory Before: 4,922.375 KB
Memory After: 4,922.586 KB
Page generated in 0.14100384712219 seconds with 9 queries, spending 0.010182619094849 doing MySQL queries and 0.13082122802734 doing PHP things.
