Time Before: 0.01305 seconds
Time After: 0.01613 seconds
Time Taken: 0.00308 seconds
Time Before: 0.01623 seconds
Time After: 0.01665 seconds
Time Before: 0.01689 seconds
Time After: 0.01702 seconds
Time Before: 0.01782 seconds
Time After: 0.02200 seconds
Time Taken: 0.00419 seconds
Time Before: 0.01709 seconds
Time After: 0.02612 seconds
Time Taken: 0.00903 seconds
Time Before: 0.03160 seconds
Time After: 0.03198 seconds
Time Before: 0.03489 seconds
Time After: 0.03613 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.03082 seconds
Time After: 0.03638 seconds
Time Taken: 0.00556 seconds
Memory After: 2,261.719 KB
Time Before: 0.05827 seconds
Time After: 0.05844 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.06834 seconds
Time After: 0.06958 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
End call of global.php: 0.071647167205811
Time Before: 0.07532 seconds
Time After: 0.07545 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.07768 seconds
Time After: 0.07915 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=7803'
Time Before: 0.09567 seconds
Time After: 0.09609 seconds
Memory Before: 4,287.219 KB
Memory After: 4,287.469 KB
Memory Used: 0.250 KB
Page generated in 0.094658136367798 seconds with 9 queries, spending 0.0097901821136475 doing MySQL queries and 0.08486795425415 doing PHP things.
