Time Before: 0.01036 seconds
Time After: 0.01356 seconds
Time Taken: 0.00320 seconds
Time Before: 0.01366 seconds
Time After: 0.01411 seconds
Time Before: 0.01435 seconds
Time After: 0.01450 seconds
Time Before: 0.01522 seconds
Time After: 0.01741 seconds
Time Taken: 0.00219 seconds
Time Before: 0.01457 seconds
Time After: 0.02174 seconds
Time Taken: 0.00718 seconds
Time Before: 0.02702 seconds
Time After: 0.02739 seconds
Time Before: 0.03007 seconds
Time After: 0.03139 seconds
Time Taken: 0.00131 seconds
Time Before: 0.02628 seconds
Time After: 0.03166 seconds
Time Taken: 0.00538 seconds
Time Before: 0.05259 seconds
Time After: 0.05275 seconds
Time Before: 0.05977 seconds
Time After: 0.06104 seconds
End call of global.php: 0.063455820083618
Time Before: 0.06983 seconds
Time After: 0.06999 seconds
Time Before: 0.07289 seconds
Time After: 0.07440 seconds
Time Taken: 0.00151 seconds
SET lastactivity = 1784785554, location = '/forums/private.php?do=newpm&explain=1&u=78116', badlocation = 1
Time Before: 0.09269 seconds
Time After: 0.09299 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
Page generated in 0.091781854629517 seconds with 9 queries, spending 0.0078988075256348 doing MySQL queries and 0.083883047103882 doing PHP things.
