Time Before: 0.00177 seconds
Time After: 0.00228 seconds
Time Before: 0.00234 seconds
Time After: 0.00294 seconds
Time Taken: 0.00059 seconds
Time Before: 0.00314 seconds
Time After: 0.00326 seconds
Time Before: 0.00400 seconds
Time After: 0.00690 seconds
Time Taken: 0.00290 seconds
Time Before: 0.00331 seconds
Time After: 0.01024 seconds
Time Taken: 0.00694 seconds
Time Before: 0.01204 seconds
Time After: 0.01250 seconds
Time Before: 0.01593 seconds
Time After: 0.01716 seconds
Time Before: 0.01144 seconds
Time After: 0.01753 seconds
Time Taken: 0.00609 seconds
Time Before: 0.02367 seconds
Time After: 0.02386 seconds
Time Before: 0.02580 seconds
Time After: 0.02717 seconds
Time Taken: 0.00137 seconds
Time Before: 0.03165 seconds
Time After: 0.03184 seconds
Time Before: 0.03428 seconds
Time After: 0.03568 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=78126' WHERE sessionhash = '7ca6ab718f0d2129a0db1a6bd7e3c55b'
Time Before: 0.04836 seconds
Time After: 0.04861 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
