Time Before: 0.01459 seconds
Time After: 0.01968 seconds
Time Taken: 0.00508 seconds
Memory Before: 1,246.203 KB
Memory After: 1,273.008 KB
Time Before: 0.01977 seconds
Time After: 0.02021 seconds
Memory Before: 1,272.969 KB
Memory After: 1,273.945 KB
Time Before: 0.02048 seconds
Time After: 0.02061 seconds
Memory Before: 1,274.586 KB
Memory After: 1,275.109 KB
Time Before: 0.02141 seconds
Time After: 0.02397 seconds
Time Taken: 0.00255 seconds
Memory Before: 1,277.977 KB
Memory After: 1,278.898 KB
Time Before: 0.02071 seconds
Time After: 0.02801 seconds
Time Taken: 0.00730 seconds
Memory Before: 1,274.391 KB
Memory After: 2,355.609 KB
Memory Used: 1,081.219 KB
Time Before: 0.03524 seconds
Time After: 0.03565 seconds
Memory Before: 2,895.875 KB
Memory After: 2,896.492 KB
Time Before: 0.03816 seconds
Time After: 0.03939 seconds
Memory Before: 2,908.203 KB
Memory After: 2,908.063 KB
Time Before: 0.03456 seconds
Time After: 0.03964 seconds
Memory Before: 2,888.602 KB
Memory After: 3,021.133 KB
Memory Used: 132.531 KB
Time Before: 0.07146 seconds
Time After: 0.07160 seconds
Memory Before: 3,655.734 KB
Memory After: 3,656.250 KB
Time Before: 0.11697 seconds
Time After: 0.11820 seconds
Memory Before: 4,133.250 KB
Memory After: 4,133.844 KB
End call of global.php: 0.12039804458618
Time Before: 0.13807 seconds
Time After: 0.13832 seconds
Memory Before: 5,197.492 KB
Memory After: 5,325.836 KB
Time Before: 0.14379 seconds
Time After: 0.14528 seconds
Memory Before: 5,481.172 KB
Memory After: 5,610.773 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=7821'
Time Before: 0.16815 seconds
Time After: 0.16840 seconds
Memory Before: 5,997.422 KB
Memory After: 5,997.672 KB
Memory Used: 0.250 KB
Page generated in 0.16715312004089 seconds with 9 queries, spending 0.0081079006195068 doing MySQL queries and 0.15904521942139 doing PHP things.
