Time Before: 0.01549 seconds
Time After: 0.02080 seconds
Time Taken: 0.00531 seconds
Time Before: 0.02090 seconds
Time After: 0.02130 seconds
Time Before: 0.02153 seconds
Time After: 0.02169 seconds
Time Before: 0.02245 seconds
Time After: 0.02477 seconds
Time Taken: 0.00231 seconds
Time Before: 0.02175 seconds
Time After: 0.02890 seconds
Time Taken: 0.00715 seconds
Time Before: 0.03358 seconds
Time After: 0.03398 seconds
Time Before: 0.03525 seconds
Time After: 0.03644 seconds
Time Before: 0.03286 seconds
Time After: 0.03664 seconds
Time Taken: 0.00378 seconds
Time Before: 0.05669 seconds
Time After: 0.05685 seconds
Time Before: 0.06693 seconds
Time After: 0.06817 seconds
End call of global.php: 0.070225954055786
Time Before: 0.07545 seconds
Time After: 0.07563 seconds
Time Before: 0.07802 seconds
Time After: 0.08063 seconds
Time Taken: 0.00261 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=78247'
Time Before: 0.09823 seconds
Time After: 0.09848 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
Page generated in 0.097204923629761 seconds with 9 queries, spending 0.0089044570922852 doing MySQL queries and 0.088300466537476 doing PHP things.
