Time Before: 0.00444 seconds
Time After: 0.00714 seconds
Time Taken: 0.00270 seconds
Time Before: 0.00721 seconds
Time After: 0.00761 seconds
Time Before: 0.00782 seconds
Time After: 0.00796 seconds
Time Before: 0.00867 seconds
Time After: 0.01137 seconds
Time Before: 0.00800 seconds
Time After: 0.01590 seconds
Time Taken: 0.00790 seconds
Time Before: 0.02067 seconds
Time After: 0.02105 seconds
Time Before: 0.02339 seconds
Time After: 0.02468 seconds
Time Before: 0.01995 seconds
Time After: 0.02485 seconds
Time Taken: 0.00490 seconds
Time Before: 0.03494 seconds
Time After: 0.03510 seconds
Time Before: 0.04194 seconds
Time After: 0.04319 seconds
Time Before: 0.04795 seconds
Time After: 0.04810 seconds
Time Before: 0.05041 seconds
Time After: 0.05187 seconds
UPDATE session SET lastactivity = 1789088354, location = '/forums/private.php?do=newpm&explain=1&u=78256' WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.06937 seconds
Time After: 0.06980 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
