Time Before: 0.01804 seconds
Time After: 0.02234 seconds
Time Taken: 0.00430 seconds
Time Before: 0.02241 seconds
Time After: 0.02283 seconds
Time Before: 0.02311 seconds
Time After: 0.02325 seconds
Time Before: 0.02428 seconds
Time After: 0.02656 seconds
Time Taken: 0.00228 seconds
Time Before: 0.02333 seconds
Time After: 0.03106 seconds
Time Taken: 0.00773 seconds
Time Before: 0.04046 seconds
Time After: 0.04091 seconds
Time Before: 0.04438 seconds
Time After: 0.04559 seconds
Time Before: 0.03967 seconds
Time After: 0.04586 seconds
Time Taken: 0.00620 seconds
Time Before: 0.07904 seconds
Time After: 0.07918 seconds
Time Before: 0.09403 seconds
Time After: 0.09531 seconds
Time Before: 0.10353 seconds
Time After: 0.10370 seconds
Time Before: 0.10637 seconds
Time After: 0.10785 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=78275' WHERE sessionhash = '3c1d29d6e59a1d652dc9473cfb455cd5'
Time Before: 0.12735 seconds
Time After: 0.12766 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
