Time Before: 0.01828 seconds
Time After: 0.02405 seconds
Time Taken: 0.00577 seconds
Time Before: 0.02413 seconds
Time After: 0.02457 seconds
Time Before: 0.02480 seconds
Time After: 0.02495 seconds
Time Before: 0.02571 seconds
Time After: 0.02926 seconds
Time Taken: 0.00355 seconds
Time Before: 0.02500 seconds
Time After: 0.03325 seconds
Time Taken: 0.00826 seconds
Time Before: 0.04306 seconds
Time After: 0.04349 seconds
Time Before: 0.04597 seconds
Time After: 0.04723 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.04165 seconds
Time After: 0.04743 seconds
Time Taken: 0.00578 seconds
Memory After: 2,261.836 KB
Time Before: 0.08191 seconds
Time After: 0.08206 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.10874 seconds
Time After: 0.11002 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
Time Before: 0.12732 seconds
Time After: 0.12750 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.13082 seconds
Time After: 0.13232 seconds
Time Taken: 0.00150 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
UPDATE session SET lastactivity = 1789015963, location = '/forums/private.php?do=newpm&explain=1&u=78371' WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.15191 seconds
Time After: 0.15217 seconds
Memory Before: 4,287.578 KB
Memory After: 4,287.805 KB
