Time Before: 0.00770 seconds
Time After: 0.01037 seconds
Time Taken: 0.00267 seconds
Time Before: 0.01048 seconds
Time After: 0.01088 seconds
Time Before: 0.01115 seconds
Time After: 0.01131 seconds
Time Before: 0.01216 seconds
Time After: 0.01463 seconds
Time Taken: 0.00247 seconds
Time Before: 0.01138 seconds
Time After: 0.01889 seconds
Time Taken: 0.00751 seconds
Time Before: 0.02294 seconds
Time After: 0.02333 seconds
Time Before: 0.02637 seconds
Time After: 0.02755 seconds
Time Taken: 0.00118 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.02229 seconds
Time After: 0.02781 seconds
Time Taken: 0.00553 seconds
Memory After: 2,261.836 KB
Time Before: 0.04585 seconds
Time After: 0.04600 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.05485 seconds
Time After: 0.05611 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
End call of global.php: 0.058420181274414
Time Before: 0.06208 seconds
Time After: 0.06224 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.06463 seconds
Time After: 0.06606 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
SET lastactivity = 1788847871, location = '/forums/private.php?do=newpm&explain=1&u=78374'
Time Before: 0.08101 seconds
Time After: 0.08124 seconds
Memory Before: 4,287.578 KB
Memory After: 4,287.805 KB
Page generated in 0.080077171325684 seconds with 9 queries, spending 0.0078246593475342 doing MySQL queries and 0.072252511978149 doing PHP things.
