Time Before: 0.00370 seconds
Time After: 0.00455 seconds
Time Taken: 0.00085 seconds
Memory Before: 1,246.203 KB
Memory After: 1,273.008 KB
Time Before: 0.00463 seconds
Time After: 0.00505 seconds
Memory Before: 1,272.969 KB
Memory After: 1,273.945 KB
Time Before: 0.00532 seconds
Time After: 0.00547 seconds
Memory Before: 1,274.586 KB
Memory After: 1,275.109 KB
Time Before: 0.00633 seconds
Time After: 0.00887 seconds
Time Taken: 0.00254 seconds
Memory Before: 1,277.977 KB
Memory After: 1,278.898 KB
Time Before: 0.00555 seconds
Time After: 0.01232 seconds
Time Taken: 0.00677 seconds
Memory Before: 1,274.391 KB
Memory After: 2,355.609 KB
Memory Used: 1,081.219 KB
Time Before: 0.01422 seconds
Time After: 0.01460 seconds
Memory Before: 2,895.875 KB
Memory After: 2,896.492 KB
Time Before: 0.01694 seconds
Time After: 0.01822 seconds
Memory Before: 2,908.203 KB
Memory After: 2,908.063 KB
Time Before: 0.01362 seconds
Time After: 0.01840 seconds
Time Taken: 0.00478 seconds
Memory Before: 2,888.602 KB
Memory After: 3,021.133 KB
Memory Used: 132.531 KB
Time Before: 0.02532 seconds
Time After: 0.02544 seconds
Memory Before: 3,655.734 KB
Memory After: 3,656.250 KB
Time Before: 0.03237 seconds
Time After: 0.03362 seconds
Memory Before: 4,133.250 KB
Memory After: 4,133.844 KB
End call of global.php: 0.035311937332153
Time Before: 0.04156 seconds
Time After: 0.04171 seconds
Memory Before: 5,197.492 KB
Memory After: 5,325.836 KB
Time Before: 0.04393 seconds
Time After: 0.04538 seconds
Memory Before: 5,481.172 KB
Memory After: 5,610.773 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=78472'
WHERE sessionhash = 'e8e50c90c514c39ba0053dd18b3c9b95'
Time Before: 0.05865 seconds
Time After: 0.05892 seconds
Memory Before: 5,998.203 KB
Memory After: 5,998.445 KB
Page generated in 0.057740926742554 seconds with 9 queries, spending 0.0079898834228516 doing MySQL queries and 0.049751043319702 doing PHP things.
