Time Before: 0.00153 seconds
Time After: 0.00199 seconds
Time Before: 0.00206 seconds
Time After: 0.00252 seconds
Time Before: 0.00277 seconds
Time After: 0.00295 seconds
Time Before: 0.00360 seconds
Time After: 0.00620 seconds
Time Taken: 0.00260 seconds
Time Before: 0.00300 seconds
Time After: 0.00953 seconds
Time Taken: 0.00654 seconds
Time Before: 0.01123 seconds
Time After: 0.01144 seconds
Time Before: 0.01384 seconds
Time After: 0.01505 seconds
Time Before: 0.01066 seconds
Time After: 0.01522 seconds
Time Taken: 0.00455 seconds
Time Before: 0.01996 seconds
Time After: 0.02009 seconds
Time Before: 0.45910 seconds
Time After: 0.46077 seconds
Time Taken: 0.00167 seconds
End call of global.php: 0.46348214149475
Time Before: 0.46500 seconds
Time After: 0.46518 seconds
Time Before: 0.46793 seconds
Time After: 0.46984 seconds
Time Taken: 0.00190 seconds
SET lastactivity = 1788894177, location = '/forums/private.php?do=newpm&explain=1&u=78527', badlocation = 1
Time Before: 0.48451 seconds
Time After: 0.48511 seconds
Time Taken: 0.00060 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
Page generated in 0.48359704017639 seconds with 9 queries, spending 0.0091536045074463 doing MySQL queries and 0.47444343566895 doing PHP things.
