Time Before: 0.00889 seconds
Time After: 0.01176 seconds
Time Taken: 0.00286 seconds
Time Before: 0.01186 seconds
Time After: 0.01226 seconds
Time Before: 0.01247 seconds
Time After: 0.01260 seconds
Time Before: 0.01346 seconds
Time After: 0.01579 seconds
Time Taken: 0.00233 seconds
Time Before: 0.01268 seconds
Time After: 0.02008 seconds
Time Taken: 0.00740 seconds
Time Before: 0.02351 seconds
Time After: 0.02390 seconds
Time Before: 0.02655 seconds
Time After: 0.02779 seconds
Time Before: 0.02276 seconds
Time After: 0.02799 seconds
Time Taken: 0.00523 seconds
Time Before: 0.04075 seconds
Time After: 0.04090 seconds
Time Before: 0.04959 seconds
Time After: 0.05088 seconds
Time Before: 0.05683 seconds
Time After: 0.05704 seconds
Time Before: 0.05949 seconds
Time After: 0.06095 seconds
UPDATE session SET lastactivity = 1776463526, location = '/forums/private.php?do=newpm&explain=1&u=78611', badlocation = 1 WHERE sessionhash = '0d59333b9979c57800f17621ab8164fa'
Time Before: 0.07900 seconds
Time After: 0.07940 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
