Time Before: 0.00816 seconds
Time After: 0.01280 seconds
Time Taken: 0.00463 seconds
Time Before: 0.01291 seconds
Time After: 0.01329 seconds
Time Before: 0.01351 seconds
Time After: 0.01366 seconds
Time Before: 0.01447 seconds
Time After: 0.01683 seconds
Time Taken: 0.00236 seconds
Time Before: 0.01373 seconds
Time After: 0.02238 seconds
Time Taken: 0.00865 seconds
Time Before: 0.02901 seconds
Time After: 0.02940 seconds
Time Before: 0.03197 seconds
Time After: 0.03319 seconds
Time Before: 0.02821 seconds
Time After: 0.03343 seconds
Time Taken: 0.00523 seconds
Time Before: 0.05359 seconds
Time After: 0.05372 seconds
Time Before: 0.06181 seconds
Time After: 0.06309 seconds
End call of global.php: 0.065404176712036
Time Before: 0.06934 seconds
Time After: 0.06951 seconds
Time Before: 0.07248 seconds
Time After: 0.07393 seconds
SET lastactivity = 1783059011, location = '/forums/private.php?do=newpm&explain=1&u=78646'
Time Before: 0.09512 seconds
Time After: 0.09545 seconds
Memory Before: 4,289.125 KB
Memory After: 4,289.352 KB
Page generated in 0.093698024749756 seconds with 9 queries, spending 0.0078556537628174 doing MySQL queries and 0.085842370986938 doing PHP things.
