Time Before: 0.00454 seconds
Time After: 0.00603 seconds
Time Before: 0.00612 seconds
Time After: 0.00684 seconds
Time Taken: 0.00071 seconds
Time Before: 0.00717 seconds
Time After: 0.00745 seconds
Time Before: 0.00842 seconds
Time After: 0.01117 seconds
Time Taken: 0.00274 seconds
Time Before: 0.00753 seconds
Time After: 0.01602 seconds
Time Taken: 0.00849 seconds
Time Before: 0.01946 seconds
Time After: 0.01976 seconds
Time Before: 0.02192 seconds
Time After: 0.02314 seconds
Time Before: 0.01878 seconds
Time After: 0.02341 seconds
Time Taken: 0.00463 seconds
Time Before: 0.03514 seconds
Time After: 0.03536 seconds
Time Before: 0.03959 seconds
Time After: 0.04082 seconds
End call of global.php: 0.043408155441284
Time Before: 0.04643 seconds
Time After: 0.04658 seconds
Time Before: 0.04988 seconds
Time After: 0.05136 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=78701', badlocation = 1
Time Before: 0.07276 seconds
Time After: 0.07304 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
Page generated in 0.071327209472656 seconds with 9 queries, spending 0.0086061954498291 doing MySQL queries and 0.062721014022827 doing PHP things.
