Time Before: 0.01367 seconds
Time After: 0.01680 seconds
Time Taken: 0.00313 seconds
Memory Before: 532.906 KB
Memory After: 558.023 KB
Time Before: 0.01690 seconds
Time After: 0.01751 seconds
Time Taken: 0.00061 seconds
Memory Before: 557.961 KB
Memory After: 558.969 KB
Time Before: 0.01773 seconds
Time After: 0.01784 seconds
Memory Before: 559.523 KB
Memory After: 560.047 KB
Time Before: 0.01848 seconds
Time After: 0.02095 seconds
Time Taken: 0.00247 seconds
Memory Before: 562.648 KB
Memory After: 563.570 KB
Time Before: 0.01789 seconds
Time After: 0.02435 seconds
Time Taken: 0.00646 seconds
Memory Before: 559.297 KB
Memory After: 1,640.391 KB
Memory Used: 1,081.094 KB
Time Before: 0.02990 seconds
Time After: 0.03012 seconds
Memory Before: 2,135.344 KB
Memory After: 2,135.961 KB
Time Before: 0.03260 seconds
Time After: 0.03380 seconds
Memory Before: 2,147.523 KB
Memory After: 2,147.383 KB
Time Before: 0.02921 seconds
Time After: 0.03406 seconds
Time Taken: 0.00485 seconds
Memory Before: 2,127.523 KB
Memory After: 2,260.734 KB
Memory Used: 133.211 KB
Time Before: 0.05132 seconds
Time After: 0.05146 seconds
Memory Before: 2,814.250 KB
Memory After: 2,814.766 KB
Time Before: 0.06089 seconds
Time After: 0.06237 seconds
Memory Before: 2,902.586 KB
Memory After: 2,903.180 KB
End call of global.php: 0.064623117446899
Time Before: 0.06772 seconds
Time After: 0.06785 seconds
Memory Before: 3,539.344 KB
Memory After: 3,539.773 KB
Time Before: 0.07012 seconds
Time After: 0.07157 seconds
Memory Before: 3,821.078 KB
Memory After: 3,822.766 KB
SET lastactivity = 1783180655, location = '/forums/private.php?do=newpm&explain=1&u=78769'
Time Before: 0.08510 seconds
Time After: 0.08534 seconds
Memory Before: 4,299.250 KB
Memory After: 4,299.477 KB
Page generated in 0.084230184555054 seconds with 9 queries, spending 0.0080339908599854 doing MySQL queries and 0.076196193695068 doing PHP things.
