Time Before: 0.02946 seconds
Time After: 0.03790 seconds
Time Taken: 0.00844 seconds
Time Before: 0.03799 seconds
Time After: 0.03837 seconds
Time Before: 0.03863 seconds
Time After: 0.03875 seconds
Time Before: 0.03955 seconds
Time After: 0.04206 seconds
Time Taken: 0.00251 seconds
Time Before: 0.03881 seconds
Time After: 0.04603 seconds
Time Taken: 0.00722 seconds
Time Before: 0.05763 seconds
Time After: 0.05807 seconds
Time Before: 0.06127 seconds
Time After: 0.06250 seconds
Time Before: 0.05695 seconds
Time After: 0.06274 seconds
Time Taken: 0.00579 seconds
Time Before: 0.12108 seconds
Time After: 0.12125 seconds
Time Before: 0.14479 seconds
Time After: 0.14637 seconds
Time Taken: 0.00158 seconds
End call of global.php: 0.14894104003906
Time Before: 0.15735 seconds
Time After: 0.15757 seconds
Time Before: 0.16032 seconds
Time After: 0.16283 seconds
SET lastactivity = 1788879251, location = '/forums/private.php?do=newpm&explain=1&u=79043'
Time Before: 0.18632 seconds
Time After: 0.18676 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
Page generated in 0.18535494804382 seconds with 9 queries, spending 0.0095984935760498 doing MySQL queries and 0.17575645446777 doing PHP things.
