Time Before: 0.00157 seconds
Time After: 0.00220 seconds
Time Taken: 0.00063 seconds
Time Before: 0.00227 seconds
Time After: 0.00270 seconds
Time Before: 0.00304 seconds
Time After: 0.00319 seconds
Time Before: 0.00395 seconds
Time After: 0.00664 seconds
Time Taken: 0.00270 seconds
Time Before: 0.00327 seconds
Time After: 0.01075 seconds
Time Taken: 0.00748 seconds
Time Before: 0.01256 seconds
Time After: 0.01298 seconds
Time Before: 0.01565 seconds
Time After: 0.01689 seconds
Time Before: 0.01186 seconds
Time After: 0.01716 seconds
Time Taken: 0.00531 seconds
Time Before: 0.02544 seconds
Time After: 0.02556 seconds
Time Before: 0.02920 seconds
Time After: 0.03044 seconds
Time Before: 0.03474 seconds
Time After: 0.03502 seconds
Time Before: 0.03752 seconds
Time After: 0.03901 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=79172', badlocation = 1 WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.05457 seconds
Time After: 0.05486 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
