Time Before: 0.01365 seconds
Time After: 0.02072 seconds
Time Taken: 0.00707 seconds
Time Before: 0.02082 seconds
Time After: 0.02138 seconds
Time Taken: 0.00056 seconds
Time Before: 0.02163 seconds
Time After: 0.02182 seconds
Time Before: 0.02258 seconds
Time After: 0.02583 seconds
Time Taken: 0.00325 seconds
Time Before: 0.02188 seconds
Time After: 0.02980 seconds
Time Taken: 0.00792 seconds
Time Before: 0.03974 seconds
Time After: 0.04018 seconds
Time Before: 0.04258 seconds
Time After: 0.04384 seconds
Time Before: 0.03910 seconds
Time After: 0.04405 seconds
Time Taken: 0.00495 seconds
Time Before: 0.06623 seconds
Time After: 0.06642 seconds
Time Before: 0.08220 seconds
Time After: 0.08347 seconds
End call of global.php: 0.085919141769409
Time Before: 0.09126 seconds
Time After: 0.09145 seconds
Time Before: 0.09429 seconds
Time After: 0.09581 seconds
Time Taken: 0.00151 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=79278'
Time Before: 0.11175 seconds
Time After: 0.11216 seconds
Memory Before: 4,287.734 KB
Memory After: 4,287.977 KB
Page generated in 0.11066603660583 seconds with 9 queries, spending 0.0092742443084717 doing MySQL queries and 0.10139179229736 doing PHP things.
