Time Before: 0.01463 seconds
Time After: 0.01696 seconds
Time Taken: 0.00233 seconds
Time Before: 0.01703 seconds
Time After: 0.01751 seconds
Time Before: 0.01771 seconds
Time After: 0.01784 seconds
Time Before: 0.01867 seconds
Time After: 0.02087 seconds
Time Taken: 0.00220 seconds
Time Before: 0.01790 seconds
Time After: 0.02657 seconds
Time Taken: 0.00867 seconds
Time Before: 0.03272 seconds
Time After: 0.03316 seconds
Time Before: 0.03489 seconds
Time After: 0.03609 seconds
Time Before: 0.03191 seconds
Time After: 0.03637 seconds
Time Taken: 0.00446 seconds
Time Before: 0.05616 seconds
Time After: 0.05629 seconds
Time Before: 0.06826 seconds
Time After: 0.06952 seconds
End call of global.php: 0.071971893310547
Time Before: 0.07530 seconds
Time After: 0.07546 seconds
Time Before: 0.07833 seconds
Time After: 0.07988 seconds
Time Taken: 0.00155 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=79287'
Time Before: 0.09915 seconds
Time After: 0.09945 seconds
Memory Before: 4,287.734 KB
Memory After: 4,287.977 KB
Page generated in 0.097699880599976 seconds with 9 queries, spending 0.0078620910644531 doing MySQL queries and 0.089837789535522 doing PHP things.
