Time Before: 0.00894 seconds
Time After: 0.01148 seconds
Time Taken: 0.00254 seconds
Time Before: 0.01155 seconds
Time After: 0.01209 seconds
Time Taken: 0.00054 seconds
Time Before: 0.01237 seconds
Time After: 0.01251 seconds
Time Before: 0.01336 seconds
Time After: 0.01590 seconds
Time Before: 0.01257 seconds
Time After: 0.02109 seconds
Time Taken: 0.00851 seconds
Time Before: 0.02580 seconds
Time After: 0.02624 seconds
Time Before: 0.02875 seconds
Time After: 0.02999 seconds
Time Before: 0.02505 seconds
Time After: 0.03023 seconds
Time Taken: 0.00518 seconds
Time Before: 0.04022 seconds
Time After: 0.04041 seconds
Time Before: 0.04535 seconds
Time After: 0.04660 seconds
End call of global.php: 0.048686027526855
Time Before: 0.05186 seconds
Time After: 0.05205 seconds
Time Before: 0.05478 seconds
Time After: 0.05628 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=7948'
Time Before: 0.07245 seconds
Time After: 0.07281 seconds
Memory Before: 4,910.797 KB
Memory After: 4,911.047 KB
Memory Used: 0.250 KB
Page generated in 0.07151198387146 seconds with 9 queries, spending 0.0083718299865723 doing MySQL queries and 0.063140153884888 doing PHP things.
