Time Before: 0.00187 seconds
Time After: 0.00239 seconds
Time Before: 0.00249 seconds
Time After: 0.00311 seconds
Time Taken: 0.00063 seconds
Time Before: 0.00334 seconds
Time After: 0.00345 seconds
Time Before: 0.00421 seconds
Time After: 0.00671 seconds
Time Taken: 0.00250 seconds
Time Before: 0.00350 seconds
Time After: 0.01011 seconds
Time Taken: 0.00661 seconds
Time Before: 0.01187 seconds
Time After: 0.01233 seconds
Time Before: 0.01502 seconds
Time After: 0.01623 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.01120 seconds
Time After: 0.01640 seconds
Time Taken: 0.00520 seconds
Memory After: 2,261.719 KB
Time Before: 0.02143 seconds
Time After: 0.02160 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.02362 seconds
Time After: 0.02501 seconds
Time Taken: 0.00139 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
End call of global.php: 0.026741027832031
Time Before: 0.02791 seconds
Time After: 0.02809 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.03010 seconds
Time After: 0.03149 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=79660'
Time Before: 0.04522 seconds
Time After: 0.04557 seconds
Memory Before: 4,287.219 KB
Memory After: 4,287.461 KB
Page generated in 0.044318199157715 seconds with 9 queries, spending 0.0083909034729004 doing MySQL queries and 0.035927295684814 doing PHP things.
