Time Before: 0.00193 seconds
Time After: 0.00280 seconds
Time Taken: 0.00087 seconds
Time Before: 0.00289 seconds
Time After: 0.00360 seconds
Time Taken: 0.00071 seconds
Time Before: 0.00381 seconds
Time After: 0.00398 seconds
Time Before: 0.00492 seconds
Time After: 0.00763 seconds
Time Taken: 0.00271 seconds
Time Before: 0.00405 seconds
Time After: 0.01180 seconds
Time Taken: 0.00775 seconds
Time Before: 0.01348 seconds
Time After: 0.01394 seconds
Time Before: 0.01648 seconds
Time After: 0.01776 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.01295 seconds
Time After: 0.01793 seconds
Time Taken: 0.00498 seconds
Memory After: 2,261.836 KB
Time Before: 0.02332 seconds
Time After: 0.02351 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.02578 seconds
Time After: 0.02706 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
End call of global.php: 0.028711080551147
Time Before: 0.03000 seconds
Time After: 0.03019 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.03317 seconds
Time After: 0.03460 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
SET lastactivity = 1789147367, location = '/forums/private.php?do=newpm&explain=1&u=79678'
Time Before: 0.04717 seconds
Time After: 0.04748 seconds
Memory Before: 4,287.578 KB
Memory After: 4,287.805 KB
Page generated in 0.046231985092163 seconds with 9 queries, spending 0.008718729019165 doing MySQL queries and 0.037513256072998 doing PHP things.
