Time Before: 0.00142 seconds
Time After: 0.00187 seconds
Time Before: 0.00195 seconds
Time After: 0.00227 seconds
Time Before: 0.00244 seconds
Time After: 0.00255 seconds
Time Taken: 0.00010 seconds
Time Before: 0.00320 seconds
Time After: 0.00528 seconds
Time Taken: 0.00208 seconds
Time Before: 0.00259 seconds
Time After: 0.00874 seconds
Time Taken: 0.00615 seconds
Time Before: 0.01066 seconds
Time After: 0.01104 seconds
Time Before: 0.01254 seconds
Time After: 0.01372 seconds
Time Before: 0.00998 seconds
Time After: 0.01392 seconds
Time Taken: 0.00394 seconds
Time Before: 0.01921 seconds
Time After: 0.01933 seconds
Time Before: 0.02104 seconds
Time After: 0.02233 seconds
End call of global.php: 0.024003028869629
Time Before: 0.02536 seconds
Time After: 0.02552 seconds
Time Before: 0.02752 seconds
Time After: 0.02893 seconds
Time Taken: 0.00140 seconds
SET lastactivity = 1785399814, location = '/forums/private.php?do=newpm&explain=1&u=80087'
Time Before: 0.04283 seconds
Time After: 0.04329 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
Page generated in 0.041389942169189 seconds with 9 queries, spending 0.0075130462646484 doing MySQL queries and 0.033876895904541 doing PHP things.
