Time Before: 0.01782 seconds
Time After: 0.02206 seconds
Time Taken: 0.00423 seconds
Time Before: 0.02217 seconds
Time After: 0.02262 seconds
Time Before: 0.02285 seconds
Time After: 0.02302 seconds
Time Before: 0.02398 seconds
Time After: 0.02686 seconds
Time Taken: 0.00288 seconds
Time Before: 0.02309 seconds
Time After: 0.03113 seconds
Time Taken: 0.00804 seconds
Time Before: 0.03733 seconds
Time After: 0.03787 seconds
Time Taken: 0.00054 seconds
Time Before: 0.03935 seconds
Time After: 0.04069 seconds
Time Taken: 0.00135 seconds
Time Before: 0.03664 seconds
Time After: 0.04088 seconds
Time Taken: 0.00424 seconds
Time Before: 0.07424 seconds
Time After: 0.07441 seconds
Time Before: 0.08699 seconds
Time After: 0.08833 seconds
Time Taken: 0.00134 seconds
Time Before: 0.09818 seconds
Time After: 0.09836 seconds
Time Before: 0.10085 seconds
Time After: 0.10227 seconds
UPDATE session SET lastactivity = 1776547072, location = '/forums/private.php?do=newpm&explain=1&u=80145' WHERE sessionhash = '3d710f9993f3eccc4700b01c2edbb01a'
Time Before: 0.12168 seconds
Time After: 0.12236 seconds
Time Taken: 0.00068 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
