Time Before: 0.00129 seconds
Time After: 0.00172 seconds
Memory Before: 1,159.359 KB
Memory After: 1,184.477 KB
Time Before: 0.00179 seconds
Time After: 0.00224 seconds
Memory Before: 1,184.414 KB
Memory After: 1,185.422 KB
Time Before: 0.00248 seconds
Time After: 0.00262 seconds
Memory Before: 1,186.008 KB
Memory After: 1,186.531 KB
Time Before: 0.00352 seconds
Time After: 0.00595 seconds
Time Taken: 0.00243 seconds
Memory Before: 1,189.133 KB
Memory After: 1,190.055 KB
Time Before: 0.00269 seconds
Time After: 0.01134 seconds
Time Taken: 0.00865 seconds
Memory Before: 1,185.750 KB
Memory After: 2,266.766 KB
Time Before: 0.01313 seconds
Time After: 0.01358 seconds
Memory Before: 2,759.469 KB
Memory After: 2,760.086 KB
Time Before: 0.01666 seconds
Time After: 0.01808 seconds
Memory Before: 2,771.523 KB
Memory After: 2,771.383 KB
Time Before: 0.01252 seconds
Time After: 0.01829 seconds
Time Taken: 0.00577 seconds
Memory Before: 2,751.609 KB
Memory After: 2,884.414 KB
Time Before: 0.02368 seconds
Time After: 0.02390 seconds
Memory Before: 3,437.547 KB
Memory After: 3,438.063 KB
Time Before: 0.02656 seconds
Time After: 0.02885 seconds
Time Taken: 0.00230 seconds
Memory Before: 3,525.344 KB
Memory After: 3,525.938 KB
Time Before: 0.03367 seconds
Time After: 0.03401 seconds
Memory Before: 4,163.203 KB
Memory After: 4,163.633 KB
Time Before: 0.03647 seconds
Time After: 0.03788 seconds
Memory Before: 4,444.766 KB
Memory After: 4,446.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=8016' WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.05065 seconds
Time After: 0.05109 seconds
Memory Before: 4,918.328 KB
Memory After: 4,918.578 KB
Memory Used: 0.250 KB
