Time Before: 0.00198 seconds
Time After: 0.00262 seconds
Time Taken: 0.00064 seconds
Time Before: 0.00269 seconds
Time After: 0.00311 seconds
Time Before: 0.00336 seconds
Time After: 0.00351 seconds
Time Before: 0.00415 seconds
Time After: 0.00684 seconds
Time Taken: 0.00269 seconds
Time Before: 0.00355 seconds
Time After: 0.01124 seconds
Time Taken: 0.00769 seconds
Time Before: 0.01315 seconds
Time After: 0.01365 seconds
Time Before: 0.01610 seconds
Time After: 0.01735 seconds
Time Before: 0.01259 seconds
Time After: 0.01753 seconds
Time Taken: 0.00494 seconds
Time Before: 0.02248 seconds
Time After: 0.02262 seconds
Time Before: 0.02441 seconds
Time After: 0.02565 seconds
Time Before: 0.02865 seconds
Time After: 0.02881 seconds
Time Before: 0.03091 seconds
Time After: 0.03234 seconds
UPDATE session SET lastactivity = 1788920152, location = '/forums/private.php?do=newpm&explain=1&u=80224' WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.04569 seconds
Time After: 0.04593 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
