Time Before: 0.00411 seconds
Time After: 0.00605 seconds
Time Taken: 0.00194 seconds
Time Before: 0.00614 seconds
Time After: 0.00739 seconds
Time Before: 0.00763 seconds
Time After: 0.00779 seconds
Time Before: 0.00846 seconds
Time After: 0.01062 seconds
Time Taken: 0.00216 seconds
Time Before: 0.00783 seconds
Time After: 0.01415 seconds
Time Taken: 0.00632 seconds
Time Before: 0.01590 seconds
Time After: 0.01626 seconds
Time Before: 0.01892 seconds
Time After: 0.02016 seconds
Time Before: 0.01533 seconds
Time After: 0.02041 seconds
Time Taken: 0.00508 seconds
Time Before: 0.02731 seconds
Time After: 0.02747 seconds
Time Before: 0.02974 seconds
Time After: 0.03099 seconds
End call of global.php: 0.032737970352173
Time Before: 0.03391 seconds
Time After: 0.03411 seconds
Time Before: 0.03617 seconds
Time After: 0.03763 seconds
SET lastactivity = 1789072053, location = '/forums/private.php?do=newpm&explain=1&u=80277', badlocation = 1
Time Before: 0.05108 seconds
Time After: 0.05159 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
Page generated in 0.050060987472534 seconds with 9 queries, spending 0.0087454319000244 doing MySQL queries and 0.04131555557251 doing PHP things.
