Time Before: 0.00135 seconds
Time After: 0.00177 seconds
Time Before: 0.00184 seconds
Time After: 0.00225 seconds
Time Before: 0.00249 seconds
Time After: 0.00260 seconds
Time Before: 0.00334 seconds
Time After: 0.00554 seconds
Time Taken: 0.00221 seconds
Time Before: 0.00265 seconds
Time After: 0.00901 seconds
Time Taken: 0.00635 seconds
Time Before: 0.01095 seconds
Time After: 0.01136 seconds
Time Before: 0.01439 seconds
Time After: 0.01562 seconds
Time Before: 0.01032 seconds
Time After: 0.01579 seconds
Time Taken: 0.00547 seconds
Time Before: 0.02091 seconds
Time After: 0.02108 seconds
Time Before: 0.02318 seconds
Time After: 0.02440 seconds
Time Before: 0.02771 seconds
Time After: 0.02784 seconds
Time Before: 0.02987 seconds
Time After: 0.03129 seconds
UPDATE session SET lastactivity = 1788905798, location = '/forums/private.php?do=newpm&explain=1&u=80337', badlocation = 1 WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.04371 seconds
Time After: 0.04400 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
