Time Before: 0.01896 seconds
Time After: 0.02841 seconds
Time Taken: 0.00945 seconds
Memory Before: 1,244.109 KB
Memory After: 1,270.914 KB
Time Before: 0.02852 seconds
Time After: 0.02895 seconds
Memory Before: 1,270.875 KB
Memory After: 1,271.852 KB
Time Before: 0.02917 seconds
Time After: 0.02933 seconds
Memory Before: 1,272.492 KB
Memory After: 1,273.016 KB
Time Before: 0.03015 seconds
Time After: 0.03235 seconds
Time Taken: 0.00220 seconds
Memory Before: 1,275.883 KB
Memory After: 1,276.805 KB
Time Before: 0.02941 seconds
Time After: 0.03637 seconds
Time Taken: 0.00696 seconds
Memory Before: 1,272.297 KB
Memory After: 2,353.500 KB
Memory Used: 1,081.203 KB
Time Before: 0.04698 seconds
Time After: 0.04742 seconds
Memory Before: 2,893.758 KB
Memory After: 2,894.375 KB
Time Before: 0.04880 seconds
Time After: 0.05000 seconds
Memory Before: 2,906.086 KB
Memory After: 2,905.945 KB
Time Before: 0.04617 seconds
Time After: 0.05031 seconds
Time Taken: 0.00414 seconds
Memory Before: 2,886.484 KB
Memory After: 3,019.344 KB
Memory Used: 132.859 KB
Time Before: 0.09641 seconds
Time After: 0.09654 seconds
Memory Before: 3,653.906 KB
Memory After: 3,654.422 KB
Time Before: 0.15917 seconds
Time After: 0.16045 seconds
Memory Before: 4,131.625 KB
Memory After: 4,132.219 KB
End call of global.php: 0.16299104690552
Time Before: 0.18402 seconds
Time After: 0.18419 seconds
Memory Before: 5,195.820 KB
Memory After: 5,324.164 KB
Time Before: 0.18786 seconds
Time After: 0.18934 seconds
Memory Before: 5,479.523 KB
Memory After: 5,609.125 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=80364'
WHERE sessionhash = '4107984102e2914075bf6bfb65da9afe'
Time Before: 0.21807 seconds
Time After: 0.21838 seconds
Memory Before: 6,008.391 KB
Memory After: 6,008.633 KB
Page generated in 0.21679997444153 seconds with 9 queries, spending 0.0077998638153076 doing MySQL queries and 0.20900011062622 doing PHP things.
