Time Before: 0.01406 seconds
Time After: 0.01852 seconds
Time Taken: 0.00447 seconds
Time Before: 0.01864 seconds
Time After: 0.01906 seconds
Time Before: 0.01926 seconds
Time After: 0.01942 seconds
Time Before: 0.02023 seconds
Time After: 0.02313 seconds
Time Taken: 0.00290 seconds
Time Before: 0.01950 seconds
Time After: 0.02723 seconds
Time Taken: 0.00773 seconds
Time Before: 0.03382 seconds
Time After: 0.03406 seconds
Time Before: 0.03670 seconds
Time After: 0.03790 seconds
Time Before: 0.03299 seconds
Time After: 0.03813 seconds
Time Taken: 0.00515 seconds
Time Before: 0.07114 seconds
Time After: 0.07128 seconds
Time Before: 0.22115 seconds
Time After: 0.22239 seconds
End call of global.php: 0.22459292411804
Time Before: 0.23185 seconds
Time After: 0.23199 seconds
Time Before: 0.23496 seconds
Time After: 0.23639 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=80365', badlocation = 1
Time Before: 0.25738 seconds
Time After: 0.25763 seconds
Memory Before: 4,288.016 KB
Memory After: 4,288.242 KB
Page generated in 0.25580310821533 seconds with 9 queries, spending 0.0081164836883545 doing MySQL queries and 0.24768662452698 doing PHP things.
