Time Before: 0.00136 seconds
Time After: 0.00197 seconds
Time Taken: 0.00061 seconds
Time Before: 0.00205 seconds
Time After: 0.00267 seconds
Time Taken: 0.00062 seconds
Time Before: 0.00348 seconds
Time After: 0.00363 seconds
Time Before: 0.00443 seconds
Time After: 0.00754 seconds
Time Taken: 0.00311 seconds
Time Before: 0.00370 seconds
Time After: 0.01246 seconds
Time Taken: 0.00876 seconds
Time Before: 0.01454 seconds
Time After: 0.01502 seconds
Time Before: 0.01747 seconds
Time After: 0.01871 seconds
Time Before: 0.01387 seconds
Time After: 0.01897 seconds
Time Taken: 0.00510 seconds
Time Before: 0.02460 seconds
Time After: 0.02476 seconds
Time Before: 0.02725 seconds
Time After: 0.02849 seconds
End call of global.php: 0.030472993850708
Time Before: 0.03178 seconds
Time After: 0.03193 seconds
Time Before: 0.03431 seconds
Time After: 0.03575 seconds
SET lastactivity = 1776780048, location = '/forums/private.php?do=newpm&explain=1&u=8040'
Time Before: 0.05326 seconds
Time After: 0.05358 seconds
Memory Before: 4,911.164 KB
Memory After: 4,911.383 KB
Page generated in 0.051922082901001 seconds with 9 queries, spending 0.0089364051818848 doing MySQL queries and 0.042985677719116 doing PHP things.
