Time Before: 0.01478 seconds
Time After: 0.01937 seconds
Time Taken: 0.00458 seconds
Time Before: 0.01946 seconds
Time After: 0.01994 seconds
Time Before: 0.02019 seconds
Time After: 0.02030 seconds
Time Before: 0.02110 seconds
Time After: 0.02330 seconds
Time Taken: 0.00220 seconds
Time Before: 0.02038 seconds
Time After: 0.02755 seconds
Time Taken: 0.00717 seconds
Time Before: 0.03518 seconds
Time After: 0.03542 seconds
Time Before: 0.03793 seconds
Time After: 0.03913 seconds
Time Before: 0.03445 seconds
Time After: 0.03936 seconds
Time Taken: 0.00491 seconds
Time Before: 0.07011 seconds
Time After: 0.07024 seconds
Time Before: 0.11443 seconds
Time After: 0.11568 seconds
End call of global.php: 0.11801099777222
Time Before: 0.12223 seconds
Time After: 0.12239 seconds
Time Before: 0.12456 seconds
Time After: 0.12601 seconds
SET lastactivity = 1784714315, location = '/forums/private.php?do=newpm&explain=1&u=80509'
Time Before: 0.14351 seconds
Time After: 0.14376 seconds
Memory Before: 4,288.313 KB
Memory After: 4,288.539 KB
Page generated in 0.14219093322754 seconds with 9 queries, spending 0.0074739456176758 doing MySQL queries and 0.13471698760986 doing PHP things.
