Time Before: 0.00229 seconds
Time After: 0.00292 seconds
Time Taken: 0.00063 seconds
Time Before: 0.00299 seconds
Time After: 0.00336 seconds
Time Before: 0.00357 seconds
Time After: 0.00375 seconds
Time Before: 0.00447 seconds
Time After: 0.00654 seconds
Time Taken: 0.00207 seconds
Time Before: 0.00379 seconds
Time After: 0.00996 seconds
Time Taken: 0.00617 seconds
Time Before: 0.01230 seconds
Time After: 0.01273 seconds
Time Before: 0.01593 seconds
Time After: 0.01717 seconds
Time Before: 0.01164 seconds
Time After: 0.01742 seconds
Time Taken: 0.00578 seconds
Time Before: 0.02555 seconds
Time After: 0.02593 seconds
Time Before: 0.02871 seconds
Time After: 0.02995 seconds
End call of global.php: 0.032464981079102
Time Before: 0.03407 seconds
Time After: 0.03424 seconds
Time Before: 0.03751 seconds
Time After: 0.03899 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=80510'
Time Before: 0.05768 seconds
Time After: 0.05823 seconds
Time Taken: 0.00054 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
Page generated in 0.056750059127808 seconds with 9 queries, spending 0.0081081390380859 doing MySQL queries and 0.048641920089722 doing PHP things.
