Time Before: 0.00783 seconds
Time After: 0.01070 seconds
Time Taken: 0.00287 seconds
Time Before: 0.01079 seconds
Time After: 0.01140 seconds
Time Taken: 0.00061 seconds
Time Before: 0.01162 seconds
Time After: 0.01175 seconds
Time Before: 0.01263 seconds
Time After: 0.01486 seconds
Time Taken: 0.00224 seconds
Time Before: 0.01183 seconds
Time After: 0.01898 seconds
Time Taken: 0.00715 seconds
Time Before: 0.02228 seconds
Time After: 0.02268 seconds
Time Before: 0.02583 seconds
Time After: 0.02707 seconds
Time Before: 0.02160 seconds
Time After: 0.02733 seconds
Time Taken: 0.00573 seconds
Time Before: 0.04409 seconds
Time After: 0.04422 seconds
Time Before: 0.05281 seconds
Time After: 0.05407 seconds
End call of global.php: 0.056442022323608
Time Before: 0.05927 seconds
Time After: 0.05947 seconds
Time Before: 0.06298 seconds
Time After: 0.06446 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=80519'
WHERE sessionhash = '600503b925d08d481e162d46884ab830'
Time Before: 0.08037 seconds
Time After: 0.08062 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
Page generated in 0.079276084899902 seconds with 9 queries, spending 0.0079283714294434 doing MySQL queries and 0.071347713470459 doing PHP things.
