Time Before: 0.00149 seconds
Time After: 0.00240 seconds
Time Taken: 0.00091 seconds
Time Before: 0.00246 seconds
Time After: 0.00372 seconds
Time Before: 0.00394 seconds
Time After: 0.00407 seconds
Time Before: 0.00486 seconds
Time After: 0.00775 seconds
Time Taken: 0.00288 seconds
Time Before: 0.00414 seconds
Time After: 0.01265 seconds
Time Taken: 0.00850 seconds
Time Before: 0.01450 seconds
Time After: 0.01495 seconds
Time Before: 0.01752 seconds
Time After: 0.01877 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.01386 seconds
Time After: 0.01894 seconds
Time Taken: 0.00508 seconds
Memory After: 2,261.836 KB
Time Before: 0.02396 seconds
Time After: 0.02420 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.07729 seconds
Time After: 0.07880 seconds
Time Taken: 0.00150 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
End call of global.php: 0.081161022186279
Time Before: 0.08265 seconds
Time After: 0.08290 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.08501 seconds
Time After: 0.08651 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
SET lastactivity = 1788973473, location = '/forums/private.php?do=newpm&explain=1&u=80624'
Time Before: 0.10123 seconds
Time After: 0.10155 seconds
Memory Before: 4,287.578 KB
Memory After: 4,287.805 KB
Page generated in 0.10006308555603 seconds with 9 queries, spending 0.0097930431365967 doing MySQL queries and 0.090270042419434 doing PHP things.
