Time Before: 0.02258 seconds
Time After: 0.03086 seconds
Time Taken: 0.00828 seconds
Time Before: 0.03097 seconds
Time After: 0.03133 seconds
Time Before: 0.03154 seconds
Time After: 0.03166 seconds
Time Before: 0.03247 seconds
Time After: 0.03510 seconds
Time Taken: 0.00262 seconds
Time Before: 0.03171 seconds
Time After: 0.03999 seconds
Time Before: 0.05346 seconds
Time After: 0.05386 seconds
Time Before: 0.05687 seconds
Time After: 0.05809 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.05279 seconds
Time After: 0.05840 seconds
Time Taken: 0.00561 seconds
Memory After: 2,261.719 KB
Time Before: 0.07977 seconds
Time After: 0.08006 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.09668 seconds
Time After: 0.09791 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
End call of global.php: 0.10017609596252
Time Before: 0.11008 seconds
Time After: 0.11027 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.11268 seconds
Time After: 0.11411 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=80728', badlocation = 1
Time Before: 0.13768 seconds
Time After: 0.13796 seconds
Memory Before: 4,287.500 KB
Memory After: 4,287.727 KB
Page generated in 0.13628506660461 seconds with 9 queries, spending 0.0081300735473633 doing MySQL queries and 0.12815499305725 doing PHP things.
