Time Before: 0.01790 seconds
Time After: 0.02308 seconds
Time Taken: 0.00518 seconds
Time Before: 0.02317 seconds
Time After: 0.02366 seconds
Time Before: 0.02391 seconds
Time After: 0.02406 seconds
Time Before: 0.02486 seconds
Time After: 0.02752 seconds
Time Taken: 0.00266 seconds
Time Before: 0.02414 seconds
Time After: 0.03145 seconds
Time Taken: 0.00731 seconds
Time Before: 0.03875 seconds
Time After: 0.03916 seconds
Time Before: 0.04069 seconds
Time After: 0.04196 seconds
Time Before: 0.03793 seconds
Time After: 0.04223 seconds
Time Taken: 0.00430 seconds
Time Before: 0.08032 seconds
Time After: 0.08048 seconds
Time Before: 0.10075 seconds
Time After: 0.10202 seconds
End call of global.php: 0.10416007041931
Time Before: 0.11316 seconds
Time After: 0.11332 seconds
Time Before: 0.11598 seconds
Time After: 0.11745 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=8092', badlocation = 1
Time Before: 0.13597 seconds
Time After: 0.13629 seconds
Memory Before: 4,911.086 KB
Memory After: 4,911.313 KB
Page generated in 0.13492798805237 seconds with 9 queries, spending 0.008364200592041 doing MySQL queries and 0.12656378746033 doing PHP things.
