Time Before: 0.01663 seconds
Time After: 0.02056 seconds
Time Taken: 0.00393 seconds
Time Before: 0.02066 seconds
Time After: 0.02141 seconds
Time Taken: 0.00074 seconds
Time Before: 0.02185 seconds
Time After: 0.02203 seconds
Time Before: 0.02302 seconds
Time After: 0.02543 seconds
Time Taken: 0.00241 seconds
Time Before: 0.02216 seconds
Time After: 0.02911 seconds
Time Taken: 0.00695 seconds
Time Before: 0.03799 seconds
Time After: 0.03870 seconds
Time Taken: 0.00071 seconds
Time Before: 0.04026 seconds
Time After: 0.04153 seconds
Time Before: 0.03710 seconds
Time After: 0.04174 seconds
Time Taken: 0.00464 seconds
Time Before: 0.06499 seconds
Time After: 0.06517 seconds
Time Before: 0.08241 seconds
Time After: 0.08387 seconds
Time Before: 0.09427 seconds
Time After: 0.09448 seconds
Time Before: 0.09716 seconds
Time After: 0.09863 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=8096', badlocation = 1 WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.11500 seconds
Time After: 0.11528 seconds
Memory Before: 4,911.086 KB
Memory After: 4,911.313 KB
