Time Before: 0.01669 seconds
Time After: 0.02611 seconds
Time Taken: 0.00942 seconds
Time Before: 0.02622 seconds
Time After: 0.02666 seconds
Time Before: 0.02690 seconds
Time After: 0.02704 seconds
Time Before: 0.02790 seconds
Time After: 0.03033 seconds
Time Taken: 0.00244 seconds
Time Before: 0.02712 seconds
Time After: 0.03445 seconds
Time Taken: 0.00733 seconds
Time Before: 0.04518 seconds
Time After: 0.04559 seconds
Time Before: 0.04727 seconds
Time After: 0.04845 seconds
Time Taken: 0.00118 seconds
Time Before: 0.04445 seconds
Time After: 0.04867 seconds
Time Taken: 0.00421 seconds
Time Before: 0.09315 seconds
Time After: 0.09328 seconds
Time Before: 0.11197 seconds
Time After: 0.11343 seconds
End call of global.php: 0.11567401885986
Time Before: 0.12128 seconds
Time After: 0.12144 seconds
Time Before: 0.12394 seconds
Time After: 0.12621 seconds
Time Taken: 0.00228 seconds
SET lastactivity = 1783034958, location = '/forums/private.php?do=newpm&explain=1&u=81011'
Time Before: 0.14652 seconds
Time After: 0.14690 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
Page generated in 0.14541506767273 seconds with 9 queries, spending 0.0090181827545166 doing MySQL queries and 0.13639688491821 doing PHP things.
