Time Before: 0.01404 seconds
Time After: 0.01652 seconds
Time Taken: 0.00248 seconds
Memory Before: 1,246.203 KB
Memory After: 1,273.008 KB
Time Before: 0.01661 seconds
Time After: 0.01697 seconds
Memory Before: 1,272.969 KB
Memory After: 1,273.945 KB
Time Before: 0.01725 seconds
Time After: 0.01740 seconds
Memory Before: 1,274.586 KB
Memory After: 1,275.109 KB
Time Before: 0.01816 seconds
Time After: 0.02055 seconds
Time Taken: 0.00239 seconds
Memory Before: 1,277.977 KB
Memory After: 1,278.898 KB
Time Before: 0.01745 seconds
Time After: 0.02511 seconds
Time Taken: 0.00766 seconds
Memory Before: 1,274.391 KB
Memory After: 2,355.609 KB
Memory Used: 1,081.219 KB
Time Before: 0.02996 seconds
Time After: 0.03040 seconds
Memory Before: 2,895.875 KB
Memory After: 2,896.492 KB
Time Before: 0.03311 seconds
Time After: 0.03428 seconds
Time Taken: 0.00116 seconds
Memory Before: 2,908.320 KB
Memory After: 2,908.180 KB
Time Before: 0.02918 seconds
Time After: 0.03446 seconds
Time Taken: 0.00528 seconds
Memory Before: 2,888.602 KB
Memory After: 3,021.250 KB
Memory Used: 132.648 KB
Time Before: 0.05864 seconds
Time After: 0.05878 seconds
Memory Before: 3,655.805 KB
Memory After: 3,656.320 KB
Time Before: 0.09740 seconds
Time After: 0.09875 seconds
Time Taken: 0.00135 seconds
Memory Before: 4,133.352 KB
Memory After: 4,133.945 KB
End call of global.php: 0.10120010375977
Time Before: 0.11522 seconds
Time After: 0.11539 seconds
Memory Before: 5,197.547 KB
Memory After: 5,325.891 KB
Time Before: 0.11978 seconds
Time After: 0.12121 seconds
Memory Before: 5,481.227 KB
Memory After: 5,610.828 KB
SET lastactivity = 1773334062, location = '/forums/private.php?do=newpm&explain=1&u=81042'
Time Before: 0.14089 seconds
Time After: 0.14120 seconds
Memory Before: 5,997.766 KB
Memory After: 5,997.984 KB
Page generated in 0.13982915878296 seconds with 9 queries, spending 0.0078949928283691 doing MySQL queries and 0.13193416595459 doing PHP things.
