Time Before: 0.01283 seconds
Time After: 0.01722 seconds
Time Taken: 0.00439 seconds
Time Before: 0.01731 seconds
Time After: 0.01774 seconds
Time Before: 0.01795 seconds
Time After: 0.01812 seconds
Time Before: 0.01880 seconds
Time After: 0.02094 seconds
Time Taken: 0.00214 seconds
Time Before: 0.01817 seconds
Time After: 0.02578 seconds
Time Taken: 0.00761 seconds
Time Before: 0.03466 seconds
Time After: 0.03507 seconds
Time Before: 0.03802 seconds
Time After: 0.03924 seconds
Time Before: 0.03382 seconds
Time After: 0.03949 seconds
Time Taken: 0.00567 seconds
Time Before: 0.06155 seconds
Time After: 0.06172 seconds
Time Before: 0.07084 seconds
Time After: 0.07218 seconds
Time Taken: 0.00134 seconds
End call of global.php: 0.075043916702271
Time Before: 0.08102 seconds
Time After: 0.08119 seconds
Time Before: 0.08412 seconds
Time After: 0.08560 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=81167'
Time Before: 0.10202 seconds
Time After: 0.10234 seconds
Memory Before: 4,287.734 KB
Memory After: 4,287.977 KB
Page generated in 0.10090303421021 seconds with 9 queries, spending 0.0078470706939697 doing MySQL queries and 0.093055963516235 doing PHP things.
