Time Before: 0.01040 seconds
Time After: 0.01424 seconds
Time Taken: 0.00384 seconds
Time Before: 0.01434 seconds
Time After: 0.01486 seconds
Time Before: 0.01519 seconds
Time After: 0.01534 seconds
Time Before: 0.01621 seconds
Time After: 0.01822 seconds
Time Taken: 0.00200 seconds
Time Before: 0.01542 seconds
Time After: 0.02264 seconds
Time Taken: 0.00722 seconds
Time Before: 0.03224 seconds
Time After: 0.03263 seconds
Time Before: 0.03504 seconds
Time After: 0.03626 seconds
Time Before: 0.03139 seconds
Time After: 0.03647 seconds
Time Taken: 0.00508 seconds
Time Before: 0.05328 seconds
Time After: 0.05369 seconds
REPLACE INTO datastore
(title, data, unserialize)
VALUES
('loadcache', 'a:2:{s:7:\"loadavg\";s:6:\"15.60,\";s:9:\"lastcheck\";i:1788981882;}', 1)Time Before: 0.06837 seconds
Time After: 0.06889 seconds
Memory Before: 3,439.641 KB
Memory After: 3,439.891 KB
Memory Used: 0.250 KB
Time Before: 0.12744 seconds
Time After: 0.12870 seconds
Memory Before: 3,526.445 KB
Memory After: 3,527.039 KB
Time Before: 0.14276 seconds
Time After: 0.14295 seconds
Memory Before: 4,164.313 KB
Memory After: 4,164.742 KB
Time Before: 0.14593 seconds
Time After: 0.14742 seconds
Memory Before: 4,446.055 KB
Memory After: 4,447.742 KB
UPDATE session SET lastactivity = 1788981882, location = '/forums/private.php?do=newpm&explain=1&u=81192', badlocation = 1 WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.16887 seconds
Time After: 0.16913 seconds
Memory Before: 4,920.031 KB
Memory After: 4,920.242 KB
