Time Before: 0.00164 seconds
Time After: 0.00226 seconds
Time Taken: 0.00062 seconds
Time Before: 0.00233 seconds
Time After: 0.00290 seconds
Time Taken: 0.00057 seconds
Time Before: 0.00310 seconds
Time After: 0.00327 seconds
Time Before: 0.00408 seconds
Time After: 0.00669 seconds
Time Taken: 0.00261 seconds
Time Before: 0.00332 seconds
Time After: 0.01018 seconds
Time Taken: 0.00686 seconds
Time Before: 0.01208 seconds
Time After: 0.01246 seconds
Time Before: 0.01477 seconds
Time After: 0.01598 seconds
Time Before: 0.01150 seconds
Time After: 0.01615 seconds
Time Taken: 0.00465 seconds
Time Before: 0.02255 seconds
Time After: 0.02294 seconds
Time Before: 0.02514 seconds
Time After: 0.02636 seconds
End call of global.php: 0.028120040893555
Time Before: 0.02990 seconds
Time After: 0.03004 seconds
Time Before: 0.03222 seconds
Time After: 0.03365 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=81217'
Time Before: 0.05029 seconds
Time After: 0.05057 seconds
Memory Before: 4,287.734 KB
Memory After: 4,287.977 KB
Page generated in 0.049224138259888 seconds with 9 queries, spending 0.0084125995635986 doing MySQL queries and 0.040811538696289 doing PHP things.
