Time Before: 0.00142 seconds
Time After: 0.00187 seconds
Time Before: 0.00195 seconds
Time After: 0.00255 seconds
Time Taken: 0.00060 seconds
Time Before: 0.00285 seconds
Time After: 0.00296 seconds
Time Before: 0.00365 seconds
Time After: 0.00611 seconds
Time Taken: 0.00247 seconds
Time Before: 0.00302 seconds
Time After: 0.00951 seconds
Time Taken: 0.00649 seconds
Time Before: 0.01138 seconds
Time After: 0.01184 seconds
Time Before: 0.01481 seconds
Time After: 0.01605 seconds
Time Before: 0.01085 seconds
Time After: 0.01622 seconds
Time Taken: 0.00537 seconds
Time Before: 0.02163 seconds
Time After: 0.02175 seconds
Time Before: 0.02371 seconds
Time After: 0.02495 seconds
Time Before: 0.02779 seconds
Time After: 0.02795 seconds
Time Before: 0.02991 seconds
Time After: 0.03136 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=81317' WHERE sessionhash = '6d76899e3772524375a2c635be997117'
Time Before: 0.04377 seconds
Time After: 0.04403 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
