Time Before: 0.00163 seconds
Time After: 0.00250 seconds
Time Taken: 0.00087 seconds
Memory Before: 1,157.773 KB
Memory After: 1,182.891 KB
Time Before: 0.00257 seconds
Time After: 0.00306 seconds
Memory Before: 1,182.828 KB
Memory After: 1,183.836 KB
Time Before: 0.00342 seconds
Time After: 0.00356 seconds
Memory Before: 1,184.422 KB
Memory After: 1,184.945 KB
Time Before: 0.00432 seconds
Time After: 0.00671 seconds
Time Taken: 0.00238 seconds
Memory Before: 1,187.547 KB
Memory After: 1,188.469 KB
Time Before: 0.00361 seconds
Time After: 0.01134 seconds
Time Taken: 0.00773 seconds
Memory Before: 1,184.164 KB
Memory After: 2,265.219 KB
Memory Used: 1,081.055 KB
Time Before: 0.01390 seconds
Time After: 0.01412 seconds
Memory Before: 2,758.023 KB
Memory After: 2,758.641 KB
Time Before: 0.01704 seconds
Time After: 0.01827 seconds
Memory Before: 2,770.078 KB
Memory After: 2,769.938 KB
Time Before: 0.01301 seconds
Time After: 0.01854 seconds
Time Taken: 0.00553 seconds
Memory Before: 2,750.172 KB
Memory After: 2,883.297 KB
Memory Used: 133.125 KB
Time Before: 0.02500 seconds
Time After: 0.02516 seconds
Memory Before: 3,436.438 KB
Memory After: 3,436.953 KB
Time Before: 0.02694 seconds
Time After: 0.02815 seconds
Memory Before: 3,524.234 KB
Memory After: 3,524.828 KB
End call of global.php: 0.030656099319458
Time Before: 0.03215 seconds
Time After: 0.03229 seconds
Memory Before: 4,162.117 KB
Memory After: 4,162.547 KB
Time Before: 0.03454 seconds
Time After: 0.03602 seconds
Memory Before: 4,443.680 KB
Memory After: 4,445.367 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=8147'
Time Before: 0.04867 seconds
Time After: 0.04928 seconds
Time Taken: 0.00061 seconds
Memory Before: 4,921.656 KB
Memory After: 4,921.906 KB
Memory Used: 0.250 KB
Page generated in 0.047797918319702 seconds with 9 queries, spending 0.0080511569976807 doing MySQL queries and 0.039746761322021 doing PHP things.
