Time Before: 0.00148 seconds
Time After: 0.00205 seconds
Time Taken: 0.00057 seconds
Time Before: 0.00212 seconds
Time After: 0.00257 seconds
Time Before: 0.00285 seconds
Time After: 0.00299 seconds
Time Before: 0.00411 seconds
Time After: 0.00712 seconds
Time Taken: 0.00301 seconds
Time Before: 0.00307 seconds
Time After: 0.01163 seconds
Time Taken: 0.00856 seconds
Time Before: 0.01360 seconds
Time After: 0.01418 seconds
Time Before: 0.01752 seconds
Time After: 0.02006 seconds
Time Taken: 0.00254 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.01296 seconds
Time After: 0.02037 seconds
Time Taken: 0.00741 seconds
Memory After: 2,261.719 KB
Time Before: 0.02586 seconds
Time After: 0.02598 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.02863 seconds
Time After: 0.02995 seconds
Time Taken: 0.00133 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
Time Before: 0.03294 seconds
Time After: 0.03307 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.03515 seconds
Time After: 0.03657 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=81495', badlocation = 1 WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.05015 seconds
Time After: 0.05059 seconds
Memory Before: 4,287.500 KB
Memory After: 4,287.727 KB
