Time Before: 0.02681 seconds
Time After: 0.03877 seconds
Time Taken: 0.01196 seconds
Time Before: 0.03888 seconds
Time After: 0.03947 seconds
Time Taken: 0.00059 seconds
Time Before: 0.03981 seconds
Time After: 0.04007 seconds
Time Before: 0.04088 seconds
Time After: 0.04369 seconds
Time Taken: 0.00282 seconds
Time Before: 0.04013 seconds
Time After: 0.04876 seconds
Time Taken: 0.00863 seconds
Time Before: 0.05735 seconds
Time After: 0.05783 seconds
Time Before: 0.05957 seconds
Time After: 0.06239 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.05658 seconds
Time After: 0.06261 seconds
Time Taken: 0.00603 seconds
Memory After: 2,261.719 KB
Time Before: 0.11109 seconds
Time After: 0.11127 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.13377 seconds
Time After: 0.13500 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
End call of global.php: 0.13770914077759
Time Before: 0.14538 seconds
Time After: 0.14556 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.14869 seconds
Time After: 0.15018 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=81599'
Time Before: 0.17055 seconds
Time After: 0.17080 seconds
Memory Before: 4,287.219 KB
Memory After: 4,287.461 KB
Page generated in 0.16947197914124 seconds with 9 queries, spending 0.010291337966919 doing MySQL queries and 0.15918064117432 doing PHP things.
